Bayou Bert's RV9A Web Site
Date:  3-18-2015
Number of Hours:  38.00
Brief Description:  Install of the HS and VS
Spent several days after moving to the hanger getting organized and all the
other stuff moved.
I then started the final install of the tail sections.
First installed the horzional stablizer and then the vertical stablizer.
I first had to remove the ELT, which sits under the VS.
Installed both VS and HS and connected the control tube from elevators
to the control bellcrank mid aircraft.
I also hooked up the rudder cables to the rudder.
It has a Tail
It has a Tail
